Message 1 of 15
- Mute
- Permalink
- Report
https://drive.google.com/drive/folders/1AgTz7eJzMRLR-kXo_LEHE5k127pqQ2gX?usp=sharing mass is corrrect
Post the file here.
...have to see the file, but maybe a void sweep pathed along the edge would clean it up.
@hwangt0412 wrote:
okie,i have attached the file in google drive ,you can have a check~
post the link
@hwangt0412 wrote:
i just realised there are total 3 edges that are not flattened,the other is on the left side~
You need to smooth out those transition from one spline to another of the mass.
Instead of trying to fix it, I would just redo it. Create the Solid and Void Mass Host from Surfaces of the two existing Masses, close out and use Roof by Face instead of Wall by Face.
This help?
