HOW TO FLATTEN THE EDGES? i have attached the revit file below
hwangt0412
Message 1 of 15
hwangt0412
Replies (14)
Message 2 of 15
Post the file here.
...have to see the file, but maybe a void sweep pathed along the edge would clean it up.
Message 3 of 15
hwangt0412
i caouldnt attach since the file is too big,is there any other way i can share with you?
Message 4 of 15
Is it splines or arcs?  Spline should be continuous and arcs should be tangential.
Message 5 of 15
hwangt0412
okie,i have attached the file in google drive ,you can have a check~
Message 6 of 15
post the link
Message 7 of 15
hwangt0412
i think it is spline~
Message 9 of 15
hwangt0412
i just realised there are total 3 edges that are not flattened,the other is on the left side~
Message 10 of 15
You need to smooth out those transition from one spline to another of the mass.
Message 11 of 15
hwangt0412
thank you but im not sure how to do that TT
Message 12 of 15
Instead of trying to fix it, I would just redo it. Create the Solid and Void Mass Host from Surfaces of the two existing Masses, close out and use Roof by Face instead of Wall by Face.
Message 13 of 15
hwangt0412
thank you for that,could you please send me this file that you have done?
Message 14 of 15
This help?
Message 15 of 15
hwangt0412
THANK YOU SO MUCH FOR THAT~~~
