How to fix cell view and text overlap in schedule?
after I install Revit 2017 I face a problem which is cell view in schedule . The words and the numbers are overlap, so I can not see any things. Please look to attached file
Sahay_R
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Hi Rina Sahay,
it doesn't work. what I should do?
Sahay_R
Change the body text to a larger size - row height is driven by text size -
Before -
After -
Place the schedule on to a sheet to see the results.
Rina Sahay
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
Did the solution by @Sahay_R help resolve your issue?
Also, see Modifying Schedules
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
