How to export to 3D in solid dwg, according to the adjusted layer?
CucuSetiawan
Message 1 of 9
CucuSetiawan
I've tried it for 2D layers can be adjusted. but export to the 3D layer view cannot export
The picture below I've done the layer for rebar.
I've done the layer for rebar.I've done the layer for rebar.
Under this export result, the layer in AutoCad does not exist.
I hope to get a solution
Thank you
Replies (8)
Message 3 of 9
CucuSetiawan
Mr @barthbradley
I'd like a layer arrangement. when the export layer is set.
The link provided is for export to Solid only.
Message 4 of 9
Oops. My bad. I misunderstood. As far I know, that's all hard-coded.
Message 5 of 9
CucuSetiawan
Dear @barthbradley
Thank you
I think setting this layer, it will also export to 3D solid.
Message 6 of 9
@CucuSetiawan wrote:
Dear @barthbradley
Thank you
What Layer setting are you talking about?  The 3D solid geometry is mapped automatically to predesignated in-built Categories and Subcategories.  However, 2D Projection and Cut Lines Representations can be mapped to custom Subcategories which will translate to DWG Layers upon Export . I assume that is what all those subcategories under Rebar are for. Am I right?
Message 7 of 9
That's right, regarding sub catergory rebar
I have arranged it in this section
If I export 2D sub category, there is. but for 3D solid nothing.
Sorry, my English is bad
Message 8 of 9
That's exactly how it works. You might want to head on over the API forum and ask those guys if something can be done through the API.  If you find out something interesting, would you be so kind as to post me back.  Thanks.
Message 9 of 9
CucuSetiawan
Looks like I went to the API Forum, well I'll try to find answers there, and I'll share the results with you.
Thank you for chatting with you
