Floor following topography using Dynamo
1 ANTWORT 1
Nachricht 1 von 2
r_thinagar
2942 Aufrufe, 1 Antwort
Can anyone please help me to solve this issue . When I used dynamo to floor following topography, some cases it works but in some cases it resulting this issue (Slab Shape Edit Failed).Please find the attached image.Thanks
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
Mark.Ackerley
als Antwort auf: r_thinagar
Hey,
I'm not sure which package your rooforfloor.bypoints node is from, but there's a similar one in Clockwork "Floor.SlabShapeByPoints" which I have used successfully on very complex shapes...
In your case, I suspect that if you "PruneDuplicates" that might help, perhaps get rid of points closer than 50mm?
Incidently, incase you weren't aware, Dynamo has a dedicated forum at https://forum.dynamobim.com/ where you might get more responses.
Hope that helps,
Mark
