Folder-Permission, how does it work?
Andreasdraxl
Andreasdraxl
Hello BIM360s,
i try to give a folder-permission:
i can´t give to any folder a permission.  every folder says - "permission is driven by other folder"
I want that this suppfolder should just accessible by a couple of people. I mean not by role i mean personal...
Does anyone have expierence with permissions?
KR
Andreas
Mit freundlichen Grüßen
Andreas
Revit 2022
Dynamo 2.12.0.
Navisworks 2022>IFC4
a_meteni
Hi, There's a separate forum for BIM360 and you might get more support there.
Samantha-G
Hi @Andreasdraxl
Thank you for your question.  Are you the Project Admin of this job?
The role that has been set, is what is driving that message, you will need to go into the parent folder to change it.  If you are not wanting it to inherit those rights, then you would not add that role, until you get into the sub folders where you want to add it.  Hope that helps.
Sam G, CM-BIM
Revit Certified Professional
Andreasdraxl
yes i am the project admin.
Andreas
Revit 2022
Dynamo 2.12.0.
Samantha-G
Hi @Andreasdraxl
You will need to go to the parent folder and change it not to be by role.  That is what is driving that message.
Sam G, CM-BIM
