how to export revit to dwf with layer information?
Message 1 of 9
hello,
we need to have layer information on a dwf file, so we can turn on/off different parts of the project.
how can we export revit to dwf with layer information?
thanks
Replies (8)
Message 2 of 9
dzanta
Revit can export to DWF but the layer information does not translate.  For a temporary fix, you can export Revit to DWG with layer information and then use AutoCAD to export the DWG files to DWF with layer information.  I am not sure why the layer data doesn't translate yet....still researching.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 9
DWF/DWFx exported from Revit have all the model information.  You can Hide/Unhide via the Model tree.
Message 5 of 9
dzanta
it's really annoying, because for dwg the information is there, not for dwf...
it seems that it's just a "program" thing...
Message 6 of 9
toanDN
layers are on a different part of the drawing/design review, mode info (that only appear in 3d models) is different from layer info
when you publish/export in dwf sheets there is no model info
Message 7 of 9
barthbradley,
i confirmed and the DWF6ePlot configuration was already correct, so it didn't work...
Message 8 of 9
h.rainho
Hi! is there any improvements about this revit "fail"?
Message 9 of 9
There are no layers in Revit. DWF files exported from Revit contain category information.
