- Mute
- Permalink
- Report
Our client has given us a door family to use, and I'm going through fixing/adding a few things to make it better, and noticed something strange. The default height parameters that come with all door families are different parameter types - the "Height (default)" is an instance parameter, and the "Rough Height" is a type parameter. When I open a clean door family, they are both supposed to be type parameters. When I try to edit either or, I can't switch them to the correct parameter. Anyone have an idea on how to fix this?
