I've been sent a STEP file from our factory of some equipment. I need to turn it into a Revit family to use in my project. I've opened the STEP in autocad and then saved it as a .dwg. Then i've loaded the dwg into a Revit family and all works fine. However when i then load this family into a project I cant see any of the 3D geometry, does anyone know why this is?
Josh
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Check and see if the import category in your visibility and graphics is turned OFF.
