How to Dimension a Massing (3D View)?
4 REPLIES 4
pearlofsadness
662 Views, 4 Replies
Hi, I created a massing into my architectural project and I would like to add dimensionings to the massing in 3D view. Basically what we usually do is to set workplane on that locked-3Dview and then dimension it. But with massing, I am not able to even set the workplane on it...
May I know if there's a way to set dimensions to a 3D-View Massing in an architectural project?
4 REPLIES 4
alan_eu
in reply to: pearlofsadness
Hi, @pearlofsadness
You can add dimensions directly on the mass 🙂
gdp6Jt8
krI2hjy
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
pearlofsadness
in reply to: alan_eu
what if I do not want to do it in the massing environment? Because I am looking into adding it in the project environment... 😞
alan_eu
You can do it both way: inside or outside massing edit.
JuanYusta
Hi @pearlofsadness
I do it inside the project with aligned dimension:
