how to cut walls with linked strucutral model without copy monitoring.
Message 1 of 11
Hey guys,
Is there a way to have the wall cut around structural elements from linked file without copy monitoring ?
thank you.
Replies (10)
Message 2 of 11
what do you mean? because if you just want to have a cut out of the shape, you can just use edit Profile for walls to have it around different Structural Element.
Other way is using voids.
Message 3 of 11
hey i am looking to cut all columns and beams whcih are going  through my walls and there are many instances of the same moreover as they still in design stage they are going to keep changing with each stage and i was wondering if there is a way to do it automatically without copy monitoring the elements so i can avaoid duplication.
Message 4 of 11
then I should just wait till you are done with the design stage! why doing the extra effort if it is still in design stage.
because at the moment you are now putting extra effort in the your model, when it can change any moment
Message 5 of 11
thank you very much for your input I am very well aware that there will be redundant work and the main reason why I am asking this on the forum to see if there is possible way to do this without wasted effort.
Message 6 of 11
mcernello
Hello.
I have enconutered the same problem and there seems to be no workaround but copy/monitoring the structural elements into the coordination file.
Kind regards!
Message 7 of 11
dingohot
Here is a workaround using Dynamo.
It makes new walls with profiles which are cut by linked model and replace the original walls. All of wall hosted families can be automatically re-placed but you may have to change directions of them manually if necessary.
HyunWoo Kim
Message 8 of 11
cad.23
Observer
Observer
Would you like share your script ?
Message 9 of 11
phamdat290794
Community Visitor
Community Visitor
The easiest way is to create a void family and place it at the intersection points between the wall and the structure element. it don't need edit wall profile, don't need replace element in the wall, just put a family in it and you can remove it when you don't need. You can refer my script
Message 10 of 11
dcarmonagarcia
i bought it but it didnt do anything. Bought both versions 2019 and 2022
Message 11 of 11
You bought what?
