How to create new curtain wall mullion component? .. NOT a profile!
Message 1 of 8
I'm trying to calculate the volume of a mullion based on a particular customized profile.
I have managed to create a 2D profile with parameters for the length and width, complete with a formula calculating the area.  I was hoping I could then load this into the project and create a formula to 'multiply the area of this profile by the length of the mullion' BUT Revit won't allow me to create a new mullion, it will only allow a new profile to be loaded into an already loaded mullion component.
I am wanting to use this information to input into a Life Cycle Assessment for Building Materials.
Thanks.
Replies (7)
Message 2 of 8
There isn't any needs to create new mullions or a new mullion type. Add a calculated value parameter to the mullion schedule to multiply the length of the existing mullions with the known area of the new profile that you can enter.
Message 3 of 8
Message 4 of 8
Corsten.Au
Hi
There are two types of scheduling here
1. Mullion schedule: which will give the length etc
2 material schedule
In material schedule you can extract the volume directly . As long as mullions are solid section.
Corsten
Building Designer
Message 5 of 8
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, did the recommendations help with your issue?
Please mark any posts that help with "Accept as Solution" and thanks! Likes welcome.
Message 6 of 8
Message 7 of 8
I can't seem to use the length as part of a calculated formula as it is variable? Its treated as a sweep? Or am I missing something?
Message 8 of 8
Did you create a Curtain Mullion Schedule?
