Error 1 while exporting IFC from Revit 2017
7 ANTWORTEN 7
Nachricht 1 von 8
658 Aufrufe, 7 Antworten
I am receiving an error 1 while exporting IFC from Revit 2017.  "There has been an unrecoverable error during export. Export will now be aborted". What is the solution to fix this issue?
7 ANTWORTEN 7
Nachricht 2 von 8
syman2000
als Antwort auf: Anonymous
Try these methods
1.  Audit your model
2. Detach the model if the model has workset
Try using IFC export by graphisoft Archicad.
http://www.graphisoft.com/downloads/addons/interoperability/Archive.html
The archiCAD IFC exports works well if the consultant are using ArchiCAD. I'm not sure if it works with other platform
Nachricht 3 von 8
als Antwort auf: syman2000
Thank you for you solution, I Audited and Detached the model from central. After that, I export the IFC and received the same error message. Is there any other way to solve this issue? Thank you.
Nachricht 4 von 8
syman2000
Can you post the detailed error in HTML? Also is there CAD links/import in your model?
Nachricht 5 von 8
Please see attached html error export from Revit.
Nachricht 6 von 8
syman2000
Sorry I cannot see the attachment.  Can you do a screenshot and see what those errors are? Next find that error ID and see if you can delete those object.
Nachricht 7 von 8
After expanding the error message, I don't see any additional comment on it. I have attached a screenshot of the HTML error report.
Nachricht 8 von 8
syman2000
Try uploading the Revit file so we can check what is wrong with the file.
