how to create curved railing
themodmin
Message 1 of 15
themodmin
i was wondering if it's possible to create curved glass railing to be used on stairs something like the picture attached below,
any ideas
1393881222_8573_66f5cf7c27bad30794ff2230c27db196
Replies (14)
Message 2 of 15
Alfredo_Medina
You can use the top rail, with a profile, following the curved path of a landing or floor.
Please refer to this other post:
https://forums.autodesk.com/t5/revit-architecture-forum/complex-path-for-railing-sweep/m-p/6450793/h...
Message 3 of 15
rendermaster
i attached the file here: revit 2017 version
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 4 of 15
BIM.Consultant
Check following image:
This was modeled and rendered in Revit, without any plugin. The method is to create "Curtain Panel Pattern Based" family, then create a mass surface then assign the pattern to be the created family.
BIM Consultant
Message 5 of 15
Good day sir,
Could i ask how you made the curved wall going upward?
Thanks for your help.
Gerben
Message 6 of 15
Wall by face (of a mass) is a possibility.
Message 7 of 15
Hello Ronel,
Thank you for posting your stair family, I am facing some serious issue with spiral stair on 2018 and I hope you could tell me what I am missing.
When ever I use a file like your (upgraded to 2018) or create a type myself, the rail react in a odd way while creating the railing.
Please let me know if you see where I miss something,
thank you so much,
Best,
using your fileusing your fileusing rail structureusing rail structureusing the top railusing the top rail
Message 8 of 15
rendermaster
nothing wrong onmyside....could be on your settings. mind to post your resaved rvt file for further checking..
Message 9 of 15
Hello Ronel,
Thank you so much for your answer,
I have attached a sample of the two stairs, Every parameter seam to match, its seam like the sweep type is just wrong each time I place a new railing.
Only difference I noticed is the arrow on the sketch path "toggle sketch orientation", does seam to be present on the original, when I open your file
ArrowArrow
Hope you can see where I miss something.
Message 10 of 15
Hello Ronel,
I have tested the same features in Revit 2017.2 and I couldn't find the same problem, I am now pretty sure that Revit 2018.2 has some serious issues with the railing when it come to spiral staircase.
It would be nice to have a insight of how the geometry (Sweep) has been managed in this release, if there is any new parameter we could pull to get that sweep from top working again in railings.
I'll try to reach out some product support,
Thank you,
Best,
Message 11 of 15
Hello Everyone,
Today's update for Revit 2018.3 didn't solve any of those issues,
the spiral stair railing keep having problems.
straight stair has normal railing while curve stair have strange behavior on revit 2018straight stair has normal railing while curve stair have strange behavior on revit 2018
I will have to end up having in place component, if anyone has an other idea, please let me know,
Best,
Message 12 of 15
Use a top rail with a custom thin and tall profile.  Still, it does not guarantee to work for every condition.  Chances are it can be twisted weirdly and when it happens just use an in place model with a sweep blend.
Message 13 of 15
Hello ToanDN,
Thank you for your answer, the top profile seems to have the exact same behavior on my side, unfortunately.
I'll let you know if I find anything in the future.
Background:
tested with 18.2 and 18.3 with the same issue
no problem with the 17.2
Actually we made our stair with the 17.2 version and imported in our 18.3 model ;), worked fine but definitely not stable and not very satisfy by the solution.
Thank you so much,
best regards,
G
Message 14 of 15
Kcarter2020
I'm having the same issue in 2023...any solutions for this yet?
Message 15 of 15
Sylar46
Same here, so I've decided to duplicate the default Part M  (disabled ) staircase, remove all the Risers and Treads to remain with only the right and left support then i made them the glass balustrade. So i basically have 2 staircases on top of each other - looks way better than the default railing that tapers all over the place.
staircase with a stringer balustrade.
