Sketching stairs with 2 diffrent run paths
(Revit 2015)
I'm trying to sketch one stairs path but with two diffrent runs (with landind connecting them).
The stairs has to be monolitic.
For example, in my case :
First run should be 16 stairs with riser height of 175 mm. Second run should be 12 stairs with riser height of 162.5 mm, in order to complete the stairs between the two levels. (total of 4750 mm).
landing between two runs should be 250 mm height.
Is there a way to do it as one element?
Many thanks,
Alfredo_Medina
@Anonymous
For many reasons, all risers of a stair should have the same height. You have to distribute the total height in a certain number of risers.
Is there any solution?
A simple solution is creating two stairs.
Okay, have tried it. But then I can't connect them together with a single standing... and sections views looks bad 😞
Build a model in place stair if you want it both not following the rules and looking clean at the same time.
