I'm inquiring about joining curved walls. I know you can use the arc tool to develop a curved wall in Revit, but I'm not looking to create a curve with a certain radius, so I cannot use the arc tool. In this case it would be easier if I could use the spline tool, but that's not an option. So, I drew a detail line using spline and then the pick line tool to draw in walls. However, now, they are all separate little pieces. They will not join together to be one cohesive surface (you can tell this in the 3D view). Does anybody have suggestions for how to join the walls or even how to draw a curved wall differently from what I already have?
Best
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
and why don't you just use the Tangent End Arc option for Walls?
Constantin Stroescu
Ah-hah! I was not aware of this tool. I am currently a student and just learned Revit. Thank you for your help, it works wonderfully!
@Anonymous
Please remember to mark the post that gave you the solution, using the "Accept as Solution" button.
