How to create curved curtain wall
HeadbuttJ
HeadbuttJ
I created a arbitrary form and would like to make curtain walls following the form. I could edit wall profile of the sides but do know how to deal with the front. How can I create that? Thanks.
With masses
syman2000
You may want to use curtain system. Select the surface of the mass and it will auto generate the curtainwall base on the massing shape.
You could also select the Wall and press "Edit Profile" on the Contextual Tab and change the Wall's Profile.
