On reflected ceiling demolition plan I want to show light fixture as demolish; how can I show that? Do had need to do it phases?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
At a minimum, you need existing and new phases in order to do this.
In the View in which the Light Fixture is Demoed, set the View's Phase Filter to Show New + Demo.
FWIW: You don't need a Demo Plan/Phase per se. You can Set the Light Fixture's "Demolision Phase" to a Future Project Phase. It's visibily in that Future Phase will be controlled via the View's Phase Filter.
Discover lightings at Now lighting with many varieties of lamps, ceiling lights and fans, indoor wall lights and outdoor lighting, and home lighting fixtures to suit your needs.
