How to control the hierarchy of revision orders?
Message 1 of 25
Hello
I currently work on a large scale project and we do create many revisions weekly. Is there a way where you can control where you want a revision in the sequence number system. Now when we create a revisions it always ends down with the highest seq. nr. and we have to manually move/merge it up which is extremely time demanding, beecause we have more than 300 revisions and new ones is still being created. Some we have to move up 50-100 seq. numbers.
So if there is a add inn or maybe dynamo can do so you have the option for decide a revision seq. number to control hieraki it would be outstanding. Or else it is something Autodesk should consider to create, since I believe we are not the only one with this issue.
the number 45 I want to decide where to place from start when I create, not by move up. Every move takes 15-25 seconds and if we need to move it 50 spaces its easy 20-25 minutes we use.
Best regards
Kenneth Broberg Fugl
Replies (24)
Message 21 of 25
Viveka_CD
Hi @Anonymous
Thanks for checking in.
I'm sorry for the delay in replying - I have checked with the API team who owns this capability and waiting to hear from them.
I'll post an update as soon as I hear back.
Message 22 of 25
Viveka_CD
@Anonymous
Here is an update while the issue is still in progress.
The ReorderRevisionSequence method follows a syntax in the API with C# or VB
The team is testing this revision sequencing as follows:
Step 1: Got a list of all the revisions, by ElementId
Step 2: Made a new revision at the end of the sequence
Step 3: Get element ID of new revision
Step 4: Insert revisions into the list from step 1
Step 5:ReorderRevisionSequence() with the list of IDs
Step 6: check in the UI and confirm if this is required by the customer.
Message 23 of 25
Viveka_CD
Hi @Anonymous
Please see Edit Sheet Revision by Naviate*
Dynamo coding is still in testing phase.
Let me know if this helps with your issue.
*I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note, however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk.
Please review the developer’s documentation and disclaimers before proceeding to utilize their product(s).
Message 24 of 25
paul_hohnen
....so can we now assume that this dynamo solution is not going to be developed?
Message 25 of 25
RobDraw
Do you know what happens when you assume?
Rob
