How to control the hierarchy of revision orders?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello
I currently work on a large scale project and we do create many revisions weekly. Is there a way where you can control where you want a revision in the sequence number system. Now when we create a revisions it always ends down with the highest seq. nr. and we have to manually move/merge it up which is extremely time demanding, beecause we have more than 300 revisions and new ones is still being created. Some we have to move up 50-100 seq. numbers.
So if there is a add inn or maybe dynamo can do so you have the option for decide a revision seq. number to control hieraki it would be outstanding. Or else it is something Autodesk should consider to create, since I believe we are not the only one with this issue.
the number 45 I want to decide where to place from start when I create, not by move up. Every move takes 15-25 seconds and if we need to move it 50 spaces its easy 20-25 minutes we use.
Best regards
Kenneth Broberg Fugl
