how to control level ways elements in VG
LINK  LEVEL-00LINK LEVEL-00LINK LEVEL-01 TO 02LINK LEVEL-01 TO 02
HI
I am Working on a project  client is give 3 file ,
1.document file in this file we using only annotation works only other then 2 file model linked files
1..level 00- in this file client created up to level 03 but they inform to use up to level-00
2.level 01 to 02 in this file client created up to  level 00 to level 03 in this file we are use level-00.
 now my dought is if we working in floor plan means link -level-00 and level-01 to 02 both visible
if i work in LEVEL-01 MEANS I HAVE TO SHOW LEVEL -00 FLOOR BEAMS etc..
This is to complicated to hide level-00 filed element at level 01
there is any option to control level ways element control in VG
Ilic.Andrej
I didn't quite understand but I hope this helps Smiley Very Happy....
To "hide"/"show" elements that belong to a specific level, you should consider playing with the View Range. However, sometimes that is not enough because we don't want to unify the range of view. This is why we use Plan Region. Plan Region allows you to define multiple view ranges along one floor plan view... So, in theory, you could use all links in this project and just play with plan regions.
To hide/show a specific link using VG overrides, this is how you do it:
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
