how to control level ways elements in VG
LINK  LEVEL-00LINK LEVEL-00LINK LEVEL-01 TO 02LINK LEVEL-01 TO 02
HI
I am Working on a project  client is give 3 file ,
1.document file in this file we using only annotation works only other then 2 file model linked files
1..level 00- in this file client created up to level 03 but they inform to use up to level-00
2.level 01 to 02 in this file client created up to  level 00 to level 03 in this file we are use level-00.
 now my dought is if we working in floor plan means link -level-00 and level-01 to 02 both visible
if i work in LEVEL-01 MEANS I HAVE TO SHOW LEVEL -00 FLOOR BEAMS etc..
This is to complicated to hide level-00 filed element at level 01
there is any option to control levele ways element control in VG
Hi, have you tried playing with "View Range"? Usually it helps to control the level cuts.
Corsten.Au
If the linked model is located at correct elevation, then by simple host view you should be able to see the elements.. other way is to get the view of linked file using "linked view ".. Go to 1-VG, 2- Linked Revit 3-Display settings 4- Custom - 5 By linked view and chose which level you want to see ... you may further customize it.. just look at the options..If the linked model is located at correct elevation, then by simple host view you should be able to see the elements.. other way is to get the view of linked file using "linked view ".. Go to 1-VG, 2- Linked Revit 3-Display settings 4- Custom - 5 By linked view and chose which level you want to see ... you may further customize it.. just look at the options..
Corsten
Building Designer
adjust the view range as you want in the linked files
then in the master file type vv & go to the Revit Links tab
in front of the required link press the word (By host View)
in the new window select  By Linked View then choose the corresponding view
this will work fine
Sahay_R
Do the levels in the linked and host projects match? Check that to make sure.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
