How to create a Schedule of Reporting Paramters given in Adaptive Families
Corsten.Au
Advisor Advisor
Corsten.Au
Hello
I have created foran adaptive family and gave Dimension A, and Dimension B..
and they are instance parameter..
Once I load that family in the project, is there a way to extract those parameters ( Instance, reporting )and create
a Schedule..
I can see those parameters showing when the family is selected in the project.. Just looking for a
way to create a schedule of family ..
I have attached the family as well as the project for reference.
Corsten
Building Designer
Use shared parameters for those and you can schedule them normally.
Corsten.Au
Thanks @ToanDN...
Just had a black out thinking about it... I am in general so reluctant about using
shared parameter cause in the future if that shared notepad file goes missing it
creates problem..
Am gonna post another question related..
Thanks a ton..
Corsten
Building Designer
You can always export shared parameters in a family or project to a different txt file.
