How to change transparency of a filled region
Majoco
Message 1 of 25
Majoco
Hi all,
In Revit are you able to edit the transparency of a filled region similar to AutoCAD?
In AutoCAD you can set the transparency from 0-100 but in Revit i can only see two options of either 'Opaque' or 'Transparent' under the edit type feature.
Surely there's a way to edit the transparency of a filled region in Revit?
Many thanks
Replies (24)
Message 21 of 25
ritchiesweny1989
Community Visitor
Community Visitor
Just unchecking the "masking" option in the filled regions type properties is the simplest way of doing this
Message 22 of 25
tma.abbas
Community Visitor
Community Visitor
Thank you so much that was helpful
Message 23 of 25
sepideh.m
I am working on Revit 2024. I learnt a lot in this tread, however, both solutions don't work on families for me.
I could add a filter to the project to achieve 50% transparency.
I could right-click on a filled region and changed the transparency in "override graphics in view"
But, I have filled region in my key plan, which is a nested family in the titleblock.
Both "filter" and "override graphics in view" are not options in the family.
How can I change the transparency of these filled regions?
Message 24 of 25
leilani4F9NF
have you tried the "hidden line" feature under the view menu?  (to see objects below other objects).
Message 25 of 25
mfortuneP5258
If you uncheck DRAW IN FOREGROUND that might fix the issue you are having.  After doing a search it brought me here and thought there was no solution to my issue until I unchecked that box. I had a filled region in front of an element and wanted it to be semi transparent.  By unchecking that box I guess it moved it behind the element and made it look exactly how I expected it.
