I am working on a french project, so I would like to change the names of these headers in the project
How do I do this_ It will not work with just a right click
Aidan
Solved by rxi.gg. Go to Solution.
the headings of the program? or to edit the name of a schedule, floor plan etc??
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You have to reinstall the program in french version
You can't do this
I have seen it done on another project so I was thinking it could be done
However, Revit might have done this itself? when transfering from a french language program to a english language program?
I guess so
