Hello everyone,
I am new to the forum
I come from an Archicad background of 4 years and I am starting to get frustrated about how Revit does some stuff.
I wonder if there is a way to relink a viewports in a sheet? Is there way to do it in Revit or is there a plugin for it?
I just need to recreate the common process of having existing and proposed drawings in 2 sheets. I have placed the existing viewports in a sheet, now I would like to copy them into a 'proposed' sheet and just relink this existing viewports to the proposed ones.
Is this even possible in Revit?
Is there another workflow?
Kind regards
Santiago J G Manso
You can duplicate a sheet with their views with plugins (pyRevit, for example). I think this can be done natively since 2022 version.
And then, in the views you just duplicate, apply the template you want and you got it!
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
From Revit 2022.1, you can duplicate a Sheet with the View on it, then rename the copied Sheet and View, and change the View to show new work via phase/phase filter.
In older versions, just create new Sheet, duplicate the View, change phase/phase filter, and place on the new sheet.
Adding to the list, Revit 2023 lets you select a View on a Sheet and then change that view to a different one with a dropdown selector.
Help | Swap View on Sheet | Autodesk
Right! In 2023 version you can do that!
So you can duplicate a sheet with their views with plugins (pyRevit, for example). And then, in the views you just duplicate, apply the template you want and you got it!
