How to change the highest point of roof
lindali1
Message 1 of 11
lindali1
I try to make the roof match with a truss. If I edit either slope of the roof, the highest point of the roof was changed. I tried to adjust in " offset from the roof base". it seems don't work.
Replies (10)
Message 2 of 11
You can drag it up in a section view using the grip on the peak.
You can draw a flat roof, edit subelements, add peak line and change it's elevation.
Message 3 of 11
lindali1
I am confused. Could you explain more?
I google it and try to learn to do the sub-element
"Click Modify | Floors tab - Shape Editing panel-Modify Sub Elements"
Trying to find Sub Element in Modify|Roofs. But I don't find the sub-element option
Could you please let me know what is the next step?
thank~
Message 4 of 11
Try the 1st method it maybe easier.
Message 5 of 11
lindali1
I don't get the first method. In the section view, I picked the roof and try to drag it, it can adjust the slope's angle, but the peak's location of the roof won't be changed. Do I miss something? working on the edit footprint? or Properties board?
I google a lot and still don't know how to work on it.
Could you explain in more detail? please
Message 6 of 11
d.ahmed.LW
hi @lindali1
does this help?
Message 7 of 11
lindali1
Maybe I don't explain it clearly. The slope of the roof is not the same
Message 8 of 11
lindali1
Hello All
I think I find what I want. I have spent a lot of time to figure it out.
https://www.bilibili.com/video/BV1FF411L7Au/?spm_id_from=333.337.search-card.all.click
Thank all reply my ask.
Message 9 of 11
d.ahmed.LW
Great, do mark the solution and close the topic.
Message 10 of 11
You can also do a roof by extrusion and draw the roof lines matching the truss.
Message 11 of 11
Is this what you are trying to do?
