DOOR JAMB
DOOR JAMB
anuragkhati
DOOR JAMB
anuragkhati
d.ahmed.LW
Hi @anuragkhati,
I am assuming the wall is a multi layered one. The ends can be plastered by clicking this check box in the Material settings
If this helps, please mark it as solution.
anuragkhati
NO it doesn't works
d.ahmed.LW
Please send a test file with that wall in it. (Revit 2021 or 2020 version)
anuragkhati
here is the file
d.ahmed.LW
Hey again.,
you will have to move the layer outside the Main Structure like you see in top part of the pic and at the bottom change option so that it can wrap it
anuragkhati
yes now it works ,thanx a lot
