how can i add plaster to this surface
Solved by d.ahmed.LW. Go to Solution.
Hi @anuragkhati,
I am assuming the wall is a multi layered one. The ends can be plastered by clicking this check box in the Material settings
If this helps, please mark it as solution.
Hey again.,
you will have to move the layer outside the Main Structure like you see in top part of the pic and at the bottom change option so that it can wrap it
