How to change railing type on deck
7 REPLIES 7
Message 1 of 8
tstewart
497 Views, 7 Replies
How to change railing type on a proposed two-level deck?
7 REPLIES 7
Message 2 of 8
RDAOU
in reply to: tstewart
@tstewart
Select Rail, and on the properties palette EDIT TYPE >> Duplicate
Message 3 of 8
tstewart
in reply to: RDAOU
How to make the railing completely different if the various types are not listed (i.e., wood, metal, glass, etc.)?
Thank you,
TS
Message 4 of 8
RDAOU
@tstewart
  1. First You edit and duplicate the railing type
  2. Then you have to duplicate and edit the components Example:
Top Rail
Balusters
Message 5 of 8
Thank you,
TS
If you have any existing project with such railing types then you can Transfer Project Standards > Railing, to bring them to you project.  If not, then create new railing type with new railing component types (top rail, handrail, post, baluster, etc...).
https://revitpure.com/blog/14-tips-to-understand-revit-railings
Message 6 of 8
tstewart
in reply to: ToanDN
Thank you and I did not want to try to design a railing.
Message 7 of 8
RDAOU
@tstewart
you aught to ask the right question then...How to transfer railing from one project to the other NOT how to change type and create different ones!!
Message 8 of 8
tstewart
in reply to: RDAOU
Questions and Answers should be concise, so both parties understand and I'll try harder to ask the question that I really want an answer to.
TS
Forma Design Contest
