How to change default color of a family member?
octavio2
octavio2
The Light Pole “family” under Site/Utilities which has a yellow/ochre color, I modified it to a light pole like the ones used currently for photometrics on the sites, and the mofdification seems fine, but the yellow color is to be changed to the standard brown or white color used on the site poles.  I do not see a way to change the color on the model where it was inserted and neither on the family editor.  Question: How is the default surface color of this utility Light Pole changed?
Thanks in advance.
Perhaps it's because "Self Illumination" is checked under the Appearance Tab for the Material.  The Material is coming from the Project, not the Family.
