displace elements in Revit 2019
Yara-architecture
Message 1 of 26
Yara-architecture
hello.  this toolbar that include: add, remove... don't show up when i press edit. by side of that the element change to green and i cannot add or remove any element to it. any help, thanks in advance.Screenshot (1).png
Replies (25)
Message 2 of 26
I suspect that the element you are trying to add is in another Displacement Set.  Reset it first, and then add it to another Displacement Set.
Message 3 of 26
Yara-architecture
hello. still the toolbar for editing displace elements does not show up.
Message 4 of 26
Post your file.
Message 5 of 26
Yara-architecture
its big to post. But in any case when i try to use this method. still doesn't show up the editing
Message 6 of 26
Is the "Show Annotation Categories in this View" checked?
Message 7 of 26
Yara-architecture
Yes, checked.
Message 8 of 26
You working with dual monitors?
Message 9 of 26
Yara-architecture
I still have the problem
Message 10 of 26
Yara-architecture
no just one.
Message 11 of 26
Just to clarify, are you saying that when you click on "Edit" on the Displacement Set Contextual Tab, no "Edit Displacement Set" toolbar appears.  Nothing happens.
...if the toolbar is undocked, it could just be "misplaced" (e.g. somewhere else on the screen).
Message 12 of 26
Yara-architecture
yes, exactly and the element change to green like the example I posted.
Message 13 of 26
Yara-architecture
Message 14 of 26
Yara-architecture
I also thought about that, but no still doesn't appear.
Message 15 of 26
Got me.  Have you tried another view?
...maybe disabled. Check under User Interface Tab of the Options.
Message 16 of 26
Yara-architecture
Yes, I tried another. that the first time that happened and I checked the interface nothing.
Message 17 of 26
Yara-architecture
but also why changed to green??
Message 18 of 26
That's what has me confounded. That means Edit Displacement Set is active.  Should see the Toolbar.
...how the heck do you close out of it (make it not green)???
Message 19 of 26
Yara-architecture
Yes. should, but I can not find it and why changed to green?
Message 20 of 26
Yara-architecture
yes, close out of it make it not green
