how to calculate clear area of column face started from beam face check pic insi
Message 1 of 9
 how to calculate clear area of column face started from beam face  red lines in picturesdafasdf.JPG
Replies (8)
Message 2 of 9
For one instance or for all instances in the project? One way would be to paint the surface(s) to extract the paint:area into a material takeoff schedule.
Message 3 of 9
when i paint face all area of  column face painted not the area which i wanna only sdsdfsd.JPGsdfasdfasdf.JPG
Message 4 of 9
Don't understand, but you can apply paint to individual surfaces. If you want to change the extents of the paint on that one surface, use the split tool on it.
Message 5 of 9
EDIT: Okay, I see want you are saying. The exposure on the inside face is what you're talking about. Disregard what I said then. As soon as this coffee kicks in, I'll be back. HA!
But, just to clarify...you say that those are Structural Framing families joining to a Structural Column family?
Message 6 of 9
column 30cm x 60 xm   the wall thickness 20 cm  i wanna easy way to calculate the yellow area of column ,,,
Message 7 of 9
column 30cm x 60 xm   the wall thickness 20 cm  i wanna easy way to calculate the yellow area of column ,,,            ((60-20)*height of column)asdd.JPG
Message 8 of 9
Then yes, use paint as I suggested.
If this isn't working for you, my question remains: what families are you using to create this condition?  Looks like you're using walls to me. In that case, painting the exposure should work fine.
Message 9 of 9
Paint the exposed surfaces with a material and create a material take off
schedule. There is a field called As Paint, use it to report the painted
area.
