How to anotaye spot elevation of patio in the roof ? Please help
Hi
I have patio at level 2
I want in the roof plan to put spot elevation of the patio
But it doesnt give me (circle with cros)
Thank you
Only when i put bottom unlimitted in view range it works...
Is it only this way?
cbcarch
Try using a Plan Region. You can set View Range to whatever you need, just over the Patio portion in your Roof Plan.
View Tab>Plan Views>Plan Region ( In your Roof Plan View, Make sure Plan Regions are turned on in VG> Annotation Categories )
Sketch a rectangle where you need around Patio.
Then set View Range / cut plane.
Place Spot Elevation in the view.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
chrisplyler
Well, it does not have to be "unlimited," but it does have to be low enough that you can touch the upper surface of the patio.
...or use the default "Site" plan. At 200 feet above Level 1, you'll likely see everything. Smiley Wink
Region plan view is exactly what i needed
Thanks!!!
