How the line type of "Callout" rectangle is changed?
4 REPLIES 4
octavio2
825 Views, 4 Replies
The out of the box rectangle created by the "Callout" to show a plan detail has a very weak thin line.  In AutoCAD we would prefer a thicker dashed line and is easy to change.
In Revit, how to change the line type and weight of that "Callout" rectangle to a desired personal preference?
Thanks in advance.
4 REPLIES 4
L.Maas
in reply to: octavio2
Change the Object Style of the Callout in your view(s)
Louis
Please mention Revit version, especially when uploading Revit files.
_Vijay
If want to change inside in Revit chenge like @L.Maas . Or if need in only exported autocad you can change while export in the export settings.
ennujozlagam
to follow up just type TL in your keyboard to see the actual thickness of your lines. thanks
octavio2
in reply to: L.Maas
Thanks Louis for your direction.  I used "Dash-Tight" with "7 Line Weight", and both the Callout Boundary and its Leader Line look much better now.
Forma Design Contest
