The out of the box rectangle created by the "Callout" to show a plan detail has a very weak thin line. In AutoCAD we would prefer a thicker dashed line and is easy to change.
In Revit, how to change the line type and weight of that "Callout" rectangle to a desired personal preference?
Thanks in advance.
Solved by L.Maas. Go to Solution.
Change the Object Style of the Callout in your view(s)
Louis
Please mention Revit version, especially when uploading Revit files.
to follow up just type TL in your keyboard to see the actual thickness of your lines. thanks
Thanks Louis for your direction. I used "Dash-Tight" with "7 Line Weight", and both the Callout Boundary and its Leader Line look much better now.
