How do I measure the total length of multiple lines?
svalente9GJKH
svalente9GJKH
I am trying to measure the length of multiple lines. I am used to doing this simply by clicking the poly line in Autocad and it displays the total.
Is there something similar I can do in Revit? The properties bar will only give my the length of individual segments.
Likewise with different filled regions,   is there I way I can total the sf from all regions selected?
RDAOU
@svalente9GJKH
Check this post on the following link ... it has 2 solutions
Solved: Length of a sequence of model / detail lines containing curves - Autodesk Community - Revit ...
PYREVIT addin.  SUM TOTAL is the Command.
xavier.differdange
Community Visitor
Community Visitor
Perfect! Thx a lot, work like a charm
dawsonBJB2V
Series of answers to a similar or same question have all be useful. Sure you can add them up yourself, or create a schedule that can monitor the length of each line and total them for you. But why? It is a one time use for a specific moment. If I select a series of lines that are connected (and are not in a straight line. The properties calculates area, not length.
Most disappointing response: Forcing a general user to create in Dynamo is not helpful and is frustrating. I, for one, am not a programmer and the process of using Dynamo is a deep black hole. . . at best.
There is no reason that I can think of that a simple selection of a series of connected lines cannot provide a total length in the properties.
nathaniel.mackenzie
Pyrevit. Sum total function
nathaniel.mackenzie
