How do I make a curved detail line the same distance from one point?
5 REPLIES 5
1998 Views, 5 Replies
As shown in the image, I want the dotted curved detail to be the same distance (1400mm) from the nose of the toilet the whole way along the curve. Any advice?
5 REPLIES 5
Your wording seems to indicate you want the left one below.  Your picture, however, implies you need a clearance zone around the toilet, which is the right one below.  So I show you both:
- If you want the left then draw the toilet outline curve and offset it.
- If you want the right then draw the arc using
Another approach might be to place a Detail Line, using the Pick Lines method with an Offset, and pick the edge of the toilet.
in reply to: ToanDN
Yes, spot on champ - the one on the right is what I'm after. Thank you very much.
Any idea how to make the dimension line dotted?
mauricio_mssf
Still using the same tool to complement what was suggested by @ToanDN , you can define the distance of the radius you want. just follow the steps.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
ennujozlagam
select dimension (right click) > overrides graphic in view > by element or by category > change pattern to hidden. or thanks
Forma Design Contest
