Can I import an image alongside my drawing on a sheet? Also is it possible to place a seperate Revit file drawing onto this sheet as well?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
yes you can. thanks
Thanks that worked for images but not for rvt files. Can only import dwg files?
If you want to link Revit file into sheet, first you have to create view in the current Revit file and then you have to set to Revit link view to specific view. Then you bring that view into sheet.
you can try this and see if helps. thanks
