I am an interior design student and I was wondering how I would build this type of a chair. I had little trouble with the framing, however I don't know how to create the top part as it is more organic.
Here is the chair:
I tried the revit massing environment, but due to the chair size, the lines tend to be thicker when I draw any types of lines to create a form in revit massing environment. I know it can be done somehow because the bernhardt collection offers some revit models that tend to be organic such as this one.
There is also an attachment following.
Solved by Viveka_CD. Go to Solution.
What was interesting was the fact that the geometry was broken into parts and each part was editable, but I didn't see any void objects for the curves and cuts.
Actually 3DS Max would be the way to go to model these. As long as you remember that when brought into Revit these families will be 'dumb' then you should be fine.
Hi @abran1
Welcome to the Autodesk Community!
That is an interesting chair! Thanks for sharing the model. Are you working on a theme for your project?
Editing the Bernhardt_Design-Chair is not the best option, I tried editing the profile of the arm of the chair (see pic below) and there is a possibility where you can add a shape to the arm and extrude, but creating a new extrusion from scratch is the best thing and original.
Yes, you can use a mass to create the form, how you divide the form surfaces determines the framing shape. Here is some information on creating conceptual masses:
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
