HI GUYS,
If this has happened to you , or you know how to solve this issue please help me out.
THE PROBLEM:
Although the Itemise every instance box in the Sorting/Formatting menu is unchecked,
some families are still showing up as individual items while other families are not itemised.
Screenshot attached below.
MORE INFO:
The schedule includes instances from other revit projects.
REVIT VERSION 2016
WHAT DO I WANT ? :
To not itemise every instance.
Thanks for taking the time to help me and others that have this problem. ![]()
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi @Anonymous
Please try sorting 'by name'. Revit will group objects if they are sorted.
See HERE for Sorting Fields in a Schedule
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
@ToanDN, you are quite right, the marks are different, and because of this they appeared itemised.
Drawing from @Viveka_CD reply, I realised that sorting the schedule by Mark was what made each instance appear.
SOLVED ! thanks to you both
Good to know @Anonymous
Let us know if you have additional questions.
Viveka CD
