How can you change the line weight of the 'hidden' line?
2 REPLIES 2
3586 Views, 2 Replies
I would like to change the line weight of some of my 'hidden' line types.  Is it possible to keep the style of the line but have it thicker (larger line weight)?
Thank you.
2 REPLIES 2
Yes. Under Manage/ Additional Settings/ Line Styles.
You could either modify the existing ones or create new ones.  Change the Line Weight to a different number (1 being the thinnest to 16 being the thickest).  If you need to look at the Line Weights table, it is also under Manage/ Additional Settings/ Line Weights.
spbourke
in reply to: ToanDN
Each category (Walls, floors etc.) has its own <Hidden Lines> style, which can be changed either through the Object Styles (project wide) or by the Visibility/Graphics Overrides (for a particular view).
