parts shape handling error
5 ANTWORTEN 5
Nachricht 1 von 6
2295 Aufrufe, 5 Antworten
Error Warning Message : Unable to maintain shape offsets. Which is the Rules for modifying shape PARTS?
it doesn accept my custom modify to strecth the edge attaching it in the way I need
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Expand and screenshot us what is shown.
Nachricht 3 von 6
als Antwort auf: barthbradley
For BARTH.. yeah click on the image with small size it will give you the canche to enlarge them.  Other questions:
Nothing ...do I need to see something in coarse? If i select it, I do not see anything specific.
 Is the Version 2021 of RVT  more intelligent with parts? In the image below you can watch that the walls are visibile in settings :from original , exept from the one on the top, which shows only timber frames, insulation batting lines and floor underneath.  If i reveal hidden elements:the view don t show they are inside , There is no filter also applicated on this wall, nevertheless it gives part already. I can 't see my original wall in plan but only in 3D.
Onother question: Shaple Handle comand is useful for dragging shapes that follow an horizontal, vertical edge..but when you need to extend the part shape to a diagonal or aligned line which command  is available for ?
Nachricht 4 von 6
Split the parts to smaller parts with diagonal spliting lines then shape edit them.
Nachricht 5 von 6
Hey, when I said "Expand", I was referring to the Error Box's "Expand" button.  The specifics of the Error are revealed when you press the "Expand" button.
Nachricht 6 von 6
By the way, it is not advisable to create parts then modify them too deviated from the original. If your model is complicated then you may want to model it that way from the get go. Or if the complexity can be taken cared of by details then use details.
