how can we downgrade 2019 to 2016
6 REPLIES 6
395 Views, 6 Replies
Hi, I am using Revit 2019 but our client using 2016 version? how can we downgrade 2019 to 2016?
Tags (1)
6 REPLIES 6
ennujozlagam
no.. you can't. no backward compatibility. thanks
You can't.
One option is to export your model as an IFC file, which can be opened by an earlier version, but information will be lost, so you will have to rebuild from there.
in reply to: ennujozlagam
oh, is there any solution that we can save 2016 file and client can save 2019 file?
Or any 2016 version we can still purchase? Thanks.
ennujozlagam
If you started your model in Revit 2016 then you can save and open it into Revit 2017, 2018, 2019/2020 but if you model started in Revit 2019 you can't open it in Revit 2016, 2017 and 2018, Check your Autodesk reseller in your area, ask them if you can purchase Revit 2016 or Check with Autodesk website. Thanks
As I understand you cannot do that.I had the same problem. It is a shame.
loboarch
If you are on subscription you might be able to download and use 2016, but it is outside of the "supported" releases, so you would need to get special permission. You will need to talk with your re-seller and you maybe able to get 2016, but only for special cases typically.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
