How can I show levels on the front face of my model in 3D view
AidanHawkins
Message 1 of 13
AidanHawkins
Right now my levels are shown behind the model
How can I show these to show at the front of my model like I have drawn in Red
Aidan
Replies (12)
Message 2 of 13
L.Maas
There is no setting for this.
The only way you can accomplish something like this is making use of model lines (or create a family for this)
The disadvantage of course, is that these are model elements so will show up in all views. Then you need to filter them out in those views were you do not want to see them. So seems a lot of complications for this.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 13
AidanHawkins
I am having a hard time trying to find how to turn on the visability of these model lines in VG
any ideas?
Message 4 of 13
ennujozlagam
as mentioned @L.Maas no setting by now?
try to make a double text for your level, if it is okay with you?
Message 5 of 13
constantin.stroescu
I'd create an in place  enveloping Mass and then Mass Floors with a custom Tag on the pinned 3d View..
Constantin Stroescu
Message 6 of 13
L.Maas
Maybe easiest to create a new linestyle (Manage > Additional Settings > Line Style), name it something like LEVELS. Set the appropriate line pattern, weight and colour.
In your views you can then deselect these lines in your VG, under Model Categories > Lines > LEVELS
Louis
Message 7 of 13
constantin.stroescu
..and , of course, you can hide the Mass , to let only the Mass Floors visible..
Constantin Stroescu
Message 8 of 13
AidanHawkins
Thanks for the advice
I am still stuck on trying to show lines in this 3d view
I have a view template with model category > lines , all on
but still the visibility is hidden.....
Message 9 of 13
L.Maas
Attached a project (Revit 2021) with some examples.
In the 3d view you will see two times some model lines (magenta)
When you look at plan view Level 0 you will not see the line (hidden by use of VG)
When you look at plan view Level 1 you will see the line (not hidden)
For level 2 I made a generic family. You will see it is not visible in Plan view Level 2 due to setting of visible settings in the family (not visible in Plan/RCP, Front/Back and Left/Right views).
This family can also be controlled by VG or making use of filters.
Have a look at the project to understand the concepts.
Louis
Message 10 of 13
AidanHawkins
Thanks for this
I understand how it works
The problem is I dont know why I can not see my model lines appear..
I have been given the warning: None of the created elements are visible in Floor Plan: Nivel 10_T View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I have checked the VG settings, all lines are turned on...
I have checked the active view, the lines are drawn within the active view..
I dont understand why it wont show them
Regards
Aidan
Message 11 of 13
ennujozlagam
Creating a view template that allows you to view your model lines in one view and apply them to another view is the only way to appear them.
Message 12 of 13
L.Maas
The message means that particular (sub)category is hidden somehow. This could be your VG settings, also check if filters are active that might have hidden things.
To check you also can create a new view and see if they are visible there
Louis
Message 13 of 13
AidanHawkins
They were on an invisible workset.. all fixed now
