Hi, could you see the lines on the column surface? I created a column and added a corbel. I already joined these two elements, but the line still won't go. does anyone have a solution for this?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
the only way to remove that line is to create a column family and use join geometry?
Try align the top of the coble surface with the top of the L column. If that won't work, your other option is to add the coble into the L column family and do a join geometry there.
could you tell me how to create your column? I already create L column and add corbel then JOIN them but nothing happened
1st step
2nd step
3rd step
change dimension to suit your needs
Hi @nadifa.aulia
Thanks a lot for posting your question to the forums! Have the solutions suggested by @barthbradley @ennujozlagam @syman2000 helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
How to make sure it alligned? i created the corbel by attaching it to the surface of it column
