How can i override the numerical value of a dimension text
chhuanmawia18
chhuanmawia18
I sometimes want to override the values of dimension texts with some other values ( which may be  useful in some cases due to inaccuracy of recorded site plan datas with real world values. In which i may have to show the recorded values rather than the  real site values) . Is there a way to do it without having to use the text command and replacing it manually??
Ahmed_Muharram
It’s only manual as i know
double click on the dims text and override it Or use suffix  or prefix
also there is an option called alternative dims in type prop maybe useful for you
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
chhuanmawia18
thanks for the answer but double clicking on the dim text wont allow you to change it numerically , it allows only replacing with letters. Alternative dims only shows alternative units
Insert a Unicode Character first and then the new Dimension value.
chhuanmawia18
Thank you so much .
