How can I join structural members cleanly?
6 REPLIES 6
gnarkill283
307 Views, 6 Replies
Please see images below. How can I get these members to join cleanly? These are structural elements in architecture revit. I don't have a grid line at this end of the roof if that matters.
6 REPLIES 6
in reply to: gnarkill283
Join geometry.  Beam mitering.  Cut beam and column with ref planes.  Attach column to beam and set Attachment condition to maximum interaction.
gnarkill283
in reply to: ToanDN
The north to south beam is in its own model group as well as all the west to east ones. I'm not able to click on any beam when using join geometry
gnarkill283
Actually it doesn't matter if in model group - I exploded them and still can't select any members with the join geometry tool
Are you trying to cope 'em or are they already coped with a coping distance defined?  If so, zero out the coping distance.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-M...
...you may need to adjust the cut length a bit to cope properly, if that's what you mean.
...are you meaning something like this?
I see they are HSS beams so you need to Miter them or cut them using ref planes.  If you cannot miter them, edit the family, select the 3D tube and set it to be visible for ALL detail levels (coarse, medium, fine).
See screencast.
Forma Design Contest
Technology Administrators
