How can I display windows and fixtures above the cut plane?
justinbourne.design
justinbourne.design
I have some windows and plumbing fixtures (shower heads) that I'd like to be visible in plan but since they are located above the cut-plane they're not.
I found this solution in an older thread that seems perfect but these options don't exist in the objects I need to adjust.
Can I add that function to existing families?
What about showing them via a View Underlay (e.g. Looking Up)?
For windows: create plan regions to alter the view range at the high windows
For fixtures: there are several ways.
- nest shared generic models components in the fixture family
- use invisible vertical model line so that the family is cut by the view range's cut plane
- model the fixture family at the desired height and use detail components / symbolic lines placed at the level in teh family for plan presentation
