For some reason this elevation tag is not orienting the sheet number and the drawing number separation correctly in this view. The view is rotated, and I am suspecting the problem has something to do with that. I'm also attaching the related family I made (that is clearly flawed by how it performs in this example).
Any idea how I can get the separation line, and related text, to be oriented horizontally/ Any help is greatly appreciated.
Mike
Did you use Rotate view on sheet? Try rotate the view's crop region, or create a scope box, assign to the view, and rotate the scope box.
I did rotate the crop region. I did not use the rotate on the sheet function. Never really understood the purpose of the later. ![]()
Thank ToanDN
Thanks ToanDN. Great Socratic method. I appreciate all the examples that show - so realistically - all the conditions that can exist. Something like that would be fine. I took a closer look at the text settings in the family and it appears I I just need to fiddle with the text parameters "keep readable" and "fixed rotation" to get an adequate result.
